Re: 1256 engine
Posted by The tractor vet on March 11, 2014 at 13:10:43 from (75.19.125.103):
In Reply to: 1256 engine posted by Andy in WI on March 10, 2014 at 19:22:50:
If it broke a crank if i was doing the rebuild the block would go in for a LINE BORE ( notice i said LINE BORE ) NOT a line HONE . If they can not BORE it find someone that knows what they are doing . and also if it was a lot closer i would be interested . a good possibility the reason it broke the crank is the the damper moved and when this happens it sets up harmonics and you can kiss the crank good by.
