Re: NEED IHC 284 PART
Posted by BillOHIO on March 11, 2014 at 17:14:50 from (68.73.97.109):
In Reply to: Re: NEED IHC 284 PART posted by Bob Evans on March 11, 2014 at 16:47:24:
Bob, Can't blame you. Remember alignment is critical on this drive. Back to the parts diagram, make sure rubber bushings are good in item #13 coupling. Also note item #7 shims under mounting plate.
I did a search and item #21 coupler does show that Great Lakes Equipment 1-800-634-0084 may have one. You might call and check their price . No luck on shaft so far. If they have coupler reasonable that would be one less part to rebuild.
Good luck and would be interested in where you are from ? I am located in Springfield, OH near the INTERNATIONAL Truck Plant. Bill
