Re: M Hydraulic issue, low/no pressure
Posted by F-Dean on March 12, 2014 at 06:01:16 from (75.5.72.6):
In Reply to: M Hydraulic issue, low/no pressure posted by Raymond Trum-Searah on March 11, 2014 at 15:31:15:
Switch the control rods. Them lock the Lift-all rod all the way out with the U-shaped device on the outer bracket (Vice-grip works well also.) Then you can raise and lower using other control rod connected to the "Christmas Tree"
When not using Two-way, release the Lift-all rod.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
