Farmall Tractors Discussion Board
Re: International 500 Crawler
Posted by Harold H on January 20, 1999 at 18:40:04:
In Reply to: International 500 Crawler posted by Chip Fontaine on January 19, 1999 at 11:10:00:
Chip,
The International 500 gas had 37.22 pto hp and 31.37 db hp and weighed 7458 lbs. The 500 diesel had 36.64 pto hp and 31.36 db hp and weighed 5608 lbs. It was manufactured 1965 through 1969. It change to the 500C in both gas and diesel from 1970 through 1974. The International 500E came out in 1974 and 1975 and was just an upgraded version and was available diesel only and weighed 8250 lbs.
The John Deere 450C was built 1975 through 1979 and was a larger crawler weighing 10,940 lbs. The John Deere 350B was also built 1975 to 1979 and was the direct competitor for the 500 weighing 8115 lbs and having about the same hp.
The International 100C which was built 1970 through 1974 and the 100E which was built 1974 till ? was the direct competitor for the JD 450.
All of these weights are for the tractor only without a blade or loader mounted.
Hope this information helps.
Harold H
Post a Followup
: Re: Re: International 500 Crawler
