My Super M vibrates the steering shaft/wheel with RPM just off idle. A bit faster the steering wheel stops vibrating but a drawpin loose in the drawbar will now dance. Faster than that and everything settles down. It's been like this the 40+ years I've owned the tractor - I presume this is "normal".
Keep in mind also the M crankshaft is not counterbalanced so the engine's bound to vibrate some. Now add your oversize (heavier) pistons and vibration is bound to increase.
As long as your M runs OK otherwise, I'd not be too concerned.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
