Re: 504 Verry hard to start
Posted by buckeye al on December 19, 2000 at 16:10:30 from (207.43.195.201):
In Reply to: 504 Verry hard to start posted by Billybob on December 17, 2000 at 19:14:37:
Check the ignition resistor bypass feature. Best way I've found is connect a clip lead from battery to battery side of the coil.
Later.
PS.... Don't run it this way. You'll cook your points and maybe the coil too.
Post A Followup
: Re: Re: 504 Verry hard to start
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
