A 3/4" electric drill will also crank the tractor easily. Take a hand crank and cut off the lever and handle. Grind 3 flats on the shank to fit in the drill chuck. Put a long pipe in the handle threads that will touch the ground (important). the drill will directly crank the engine. I found one on Ebay of the correct type. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
