Re: Farmall M vibration just off idle
Posted by Janicholson on March 12, 2014 at 12:09:23 from (199.17.6.25):
In Reply to: Farmall M vibration just off idle posted by Schultz on March 12, 2014 at 06:50:11:
They are an unbalanced engine (two pistons up two down that keeps it from taking out your fillings) they do vibrate with zero rubber engine mounts and unless it is much different than before you put in the clutch, it is probably normal. After a day of operation your whole body will tingle for an hour or so. If it is way different, you might have gotten something in the clutch cover that threw it out of balance. Jim
