Re: losing fire on my cub
Posted by mkirsch on March 13, 2014 at 07:15:34 from (65.199.189.6):
In Reply to: losing fire on my cub posted by IbleedIHRed on March 12, 2014 at 20:41:53:
Like others have said, there is no "fire" there.
"Fire" normally means SPARK, by the way. To check for spark, you pull the center wire off the distributor cap, slide the protective boot back, and hold it near the engine block while cranking the engine with the starter. You should get a nice blue spark that easily jumps a 1/4" gap.
If you have "fire" then "fire" is not your problem.
Not for nothing, but did you turn on the fuel? I've been bit by that once or twice myself. Tractor fires right up, runs like a sewing machine, then "loses fire." After going through all the troubleshooting to see if I had spark, I forgot to turn on the gas!
