Re: SM Live Pump Suction Hose
Posted by D Slater on March 13, 2014 at 08:10:29 from (184.14.199.60):
In Reply to: SM Live Pump Suction Hose posted by kopeck on March 13, 2014 at 07:30:25:
SM that came with live hydraulics used what's called a 1 inch suction hose and a 3/4 pressure.
Will be bigger on the OD. Manifold block that bolted to the pump had 1 and 3/4 inch pipe threads. M&W pumps on the tractors used a 3/4 suction and pressure hose. 3/4 would probably work for you. Only thing to watch for is the ends installed on some newer hose has openings a lot smaller than old hose or the hose IH used. Also depends what size hole the reservoir suction opening is tapped to.
