Posted by JJ in NE on March 14, 2014 at 07:46:14 from (65.125.127.242):
In Reply to: 986 overhaul posted by Dtk on March 12, 2014 at 17:03:35:
I agree with the guys if they are the original sleeves , I would do them all because of cavitation. The only way I wouldn"t is if the engine has a water filter kit on it . I installed #5 on my uncles 1066 years ago and with in a year we had to redo it because #1 sleeve started leaking antifreeze in the oil. The second time we completely overhauled it . I also installed a water filter kit and changed the filter at least once a year . He put nearly 7000 hours on it after that till he retired. The only thing done to the engine after the overhaul was rods and mains at 5000 hours since the overhaul. I would suggest putting on a water filter kit . If not check your coolant DCA level at least once a year, with test strips you can buy at the dealer or autoparts store. I use the Fleetguard strips, I get them at the CNH dealer or the Deere dealer. If the test strip shows the DCA level is low, I put a bottle of additive in. Good luck . JJ.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
