Re: int cub 1972 seals
Posted by Red Raider on December 19, 2000 at 19:03:24 from (208.188.21.2):
In Reply to: int cub 1972 seals posted by john on December 19, 2000 at 12:48:35:
Not sure about NAPA, but large seal and bearing houses can cross match them with part numbers. Look for the double lip seals, some of the CaseIH seals I bought for the Low-Boy were single lip.
Post A Followup
: Re: Re: int cub 1972 seals
