Posted by Jim Naden on March 15, 2014 at 02:11:52 from (70.198.64.177):
In Reply to: 1486 range stuck posted by idahofarmer on March 14, 2014 at 15:22:07:
The bar on the high low shaft can loosen and cause this problem.
The original design used a very small flat washer which would not keep the bar tight. That has been replaced by a heavier, hardened flat washer CIH p/n 87613287. 1" OD by .098" thick. ($1.90)
Avoid using too thick of a washer due to low clearance between the bolt and the speed transmission shift rod.
While you're working in this area, give all pivot points in the shifting mechanism a good lubrication.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
