Re: Hi Guys. : B-275
Posted by jdemaris on March 16, 2014 at 11:15:58 from (70.194.6.88):
In Reply to: Hi Guys. : B-275 posted by Perdido on March 15, 2014 at 22:35:05:
Any NAPA will have the oil and fuel filters. Oil
is FIL-1302. Fuel is FIL-3114. Engine is a BD144.
Glow plugs operate at less then 1 volt each and all
five are hooked in series. So if one goes bad,
none will work. Four plugs in the engine and a
5th (indicator element) in the dashboard. If you
change over to the fast-heat plugs that run on 12
volts and get hooked in series -they work better
and last much longer. Same as used in the 190D
Mercedes cars.
