Posted by fixerupper on March 17, 2014 at 18:15:32 from (100.42.82.35):
In Reply to: 1486 range stuck posted by idahofarmer on March 14, 2014 at 14:43:51:
You're working ground around Twin Falls? I'm jealous. If you know what you're doing you can reach up under the cab with the right length screwdriver or pry bar and move the linkage. Might be easier to pull the cab floor. The bolts holding the floor plate are probably large Phillips. A hammer impact screw driver might help you get them loose if they haven't been touched for awhile.
A rear wheel rim on my 1086 split on the inside and it shot cal chlor tire fluid up under the cab. A month later It was shifting into two gears at one time and just really messing up. Had to pull the floor plate and spend a day standing on my head removing, cleaning and lubricating every single moving linkage under there because of the rust from the fluid. It has cast iron weights now! Jim
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror
... [Read Article]
Latest Ad:
[More Ads]
