Re: 3pt log splitter
Posted by mike van on March 18, 2014 at 03:36:48 from (24.151.25.186):
In Reply to: 3pt log splitter posted by cazzhrdwd on March 17, 2014 at 18:40:27:
I can split wood all day on a few quarts of gasoline with a 5 hp
Briggs. Why would you want to run a full sized tractor and get
worse results? The 11 gpm and 2500 psi from a two stage pump
can"t be matched with any older tractor.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
