Re: W4 discharging
Posted by toymaker 27 on March 18, 2014 at 13:13:04 from (75.156.112.47):
In Reply to: Re: W4 discharging posted by mkirsch on March 18, 2014 at 08:00:08:
6 volt system. rechecked everything this am found the nut on the F post generater had not been tighten properly. going to try again this afternoon
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
