Re: '41 Faramll H Choke Rod
Posted by D Slater on March 18, 2014 at 17:06:27 from (184.14.199.60):
In Reply to: '41 Faramll H Choke Rod posted by Gldebr on March 18, 2014 at 15:00:32:
Two different ones were used in 41. Choke rod number you posted is for serial numbers 70410 and higher. Should be like most all H tractors except early and late. Below 70410 mounted to the left side of rear tank support and used a spring loaded loop to mount. Don't think real early H tractors used a choke rod unless equipped with electric starting. Choke rods were only listed in electrical parts early on.
Was thinking the choke rod was changed a little on real late H with the switch on the starter. But I looked and it shows the same rod for 70410 on.
This post was edited by D Slater at 18:29:56 03/18/14.
