that's right, lapping is totally obsolete. nobody does that. when guides are installed the next step is to resurface valves and seats or replace as nessesary. there is also spec's on the intake and exhaust valve seat width's. you cannot correct these by lapping. lapping used to be done after the valve and seat grind to make sure they seal. but valves are ground with an interference angle of 1 degree. the valve is ground to 44 degree's and the seat to 45 degree's. this eliminates lapping, plus give faster seating and prevents carbon from getting stuck in the seat. also the springs are checked for proper tension.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
