Re: W-9 Magneto with 12 volt custom conversion is...
Posted by rustred on March 18, 2014 at 20:14:49 from (74.214.152.80):
In Reply to: Re: W-9 Magneto with 12 volt custom conversion is... posted by Janicholson on March 18, 2014 at 20:08:09:
dist turns clockwise on gas engines. you need to know this to have correct firing order. (1342) #1 cyl. is at 2 oclock position. that's if it still has its factory position. you will need to check that also.
the diesels rotate counterclockwise.
