Posted by mkirsch on March 19, 2014 at 07:12:36 from (65.199.189.6):
In Reply to: 1566 battery size posted by Richard G. on March 18, 2014 at 15:03:00:
Originally the tractor would have had dual 3EH 6V batteries in series, one on each side of the steering column.
A 4DLT battery has roughly the same voltage and CCA rating as two 3EH batteries. 25CCA won't make a hill of beans difference.
If the battery is good, that is not your problem.
Sounds like your cables are too thin and/or you have bad connections.
You could add a second 4DLT battery in parallel, running separate cables to the starter and ground for each battery. Then I bet it will fire off like nothing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
