Re: IH 340 hydraulics
Posted by MN Mike on March 19, 2014 at 10:38:01 from (216.77.154.39):
In Reply to: IH 340 hydraulics posted by 1hunter on March 19, 2014 at 10:27:02:
pictures always help for unknown stuff.
the transmission fluid is also your hydraulic reservoir. the cap with the 3/4 inch square drive by the shifter is your fill spot. first get the back end up on a hill and see if gravity can help you get that pump primed again. hy-tran is the fluid of choice if you are low. it doesn't get full to the top. there is a check plug somewhere I don't remember at the moment.
