Re: 685 PTO
Posted by JimB2 on March 19, 2014 at 13:13:18 from (99.240.243.222):
In Reply to: 685 PTO posted by wolfman on March 19, 2014 at 07:59:23:
Hi Wolfman, does it have a cab? Most times it is the lever mechanism to PTO hydraulic valve on top of the MCV valve under the left foot rest. Usually by using a good penetrating oil and working the lever back and forth and spraying penetrating oil along the control arm. Sometimes you have to lift the rubber boot over the valve and spray it.
Also check for junk down in behind the seat binding the PTO lever mechanism.
Good luck
JimB
