Re: Valve Cover Gasket for Super A
Posted by David A on December 20, 2000 at 06:26:50 from (198.24.4.11):
In Reply to: Valve Cover Gasket for Super A posted by Tyler (MD) on December 19, 2000 at 15:58:24:
Tyler, I've got this gasket waiting to go on mine also. I'd bet the same cork gasket fits both engines. I've run into this valve cover style in the past and it can be tricky to get leak free especially if someone has over torqued the two nuts warping the cover. Here is what's worked for me in the past. Clean both the cover and head well. Check the cover edge for flatness by placing it on something flat like a sheet of glass or plywood. Bend, twist or beat it straight. If it's warped there are two choices; replace it or glue it down with an silicone type gasket glue. Assuming it's flat, lightly grease both sides of a new gasket and lay it on the head. Place the cover and lightly and evenly tighten the two nuts. If a torque value were spec'ed it would be in inch pounds so as not to warp the cover. Run it awhile and look for leaks. If it leaks, maybe try tightening a little more. If still leaking, remove it again, clean off the grease with solvent and this time use a light skim of silicone sealant on both sides. I like to avoid the sealer unless it is really needed. By the way, anyone know if this cover goes on either way or is there a front and back? The difference would be which side of the head the oil filler tube duct dumps the oil onto, straight down the pushrod holes or onto the valves. Good Luck, David
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
