Posted by gbs on March 19, 2014 at 19:39:19 from (68.115.212.154):
In Reply to: 706 MCV issues posted by red48m on March 18, 2014 at 13:51:00:
not an expert on mcv's but I've run into the pressure bouncing,it can be caused by cavitation add about 5 gallons of fluid more than it holds full and see if that helps the pressure bouncing, check the dump valve to make sure it's seating,also remove the bottom plug in the mcv valve then remove the pressure relief valve that is above the plug the o-ring will go bad and lose pressure,it is non serviceable look it over to see if the spring is damaged or valve is stuck open,it would pay to pressure and flow check the mvc pump,don't want to tell you wrong but if I remember correct the pump should produce around 9 gpm at 1300# psi new, don't know what the minimum is ,roughly 4.5 to 5 gal is priority to the steering & brakes rest is for TA and lube
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
