Re: IH 340 hydraulics
Posted by PUTTER on March 20, 2014 at 06:36:16 from (12.251.225.250):
In Reply to: IH 340 hydraulics posted by 1hunter on March 19, 2014 at 10:27:02:
The check plug is under the clutch side foot board. Look for a plug with a small bolt in it, remove bolt, fill till it comes out. When I have that problem on mine I crack the line that comes from the pump where it goes from rubber to steel. Loosen it some and watch for bubbles at high idle, when she catches prime tighten it up quick. The unit with cap by the distributor is where you add engine oil. Good luck
