Re: 1566 battery size
Posted by mkirsch on March 20, 2014 at 11:46:29 from (65.199.189.6):
In Reply to: 1566 battery size posted by Owen Aaland on March 20, 2014 at 11:01:55:
X2
In series, you add Volts.
In parallel, you add CCA.
Two 6V in series will give you 12V and 850CCA, which may not crank the tractor if the starter or cables are iffy.
Two 6V in parallel will give you 6V and 1700CCA, which definitely won't crank the tractor.
Two 4DLT's in parallel will give you 12V and 1600-1800CCA depending on the brand.
