Re: 8 volt battery in an H?
Posted by AJB-830 on March 20, 2014 at 14:59:45 from (50.50.146.211):
In Reply to: 8 volt battery in an H? posted by Alan in VA on March 20, 2014 at 04:58:41:
Maybe 30 years ago my dad ran an 8-volt battery in an H that he used in winter to haul manure. Nothing was changed other than it was set to the low charge rate as it had the cut-out. If I remember, it charged about 8-10 amps on the low rate. Not sure what would happen if your tractor is equipped with a voltage regulator. I still have the same tractor but went back to 6-volts since tractor is no longer used in winter. Al
