Re: 1952 cub tractor lights
Posted by gene bender on March 21, 2014 at 02:58:04 from (207.177.56.213):
In Reply to: 1952 cub tractor lights posted by Sid--MS on March 20, 2014 at 16:21:29:
You need the system hooked positive ground. Did you get the correct reg for the CUB gen then polarize the gen.
