Tractor values
Posted by LeeinIL on March 21, 2014 at 13:06:54 from (70.194.65.122):
I am curious on the value of a couple of tractors that I am looking at. The first is a 560 Diesel, not running but loose good TA really good 15.5 -38 tires tin work is all there and straight with good emblems. It also has a fast hitch. The second is a 400 gas, running good tin decent paint fair tires, no fast hitch. The third is a Regular on steel, no lugs but does have rubber tire tread bolted to the rims. I believe the motor may be stuck from sitting but I dont know for sure if it is or not. Not for sure if the lugs are available or not. It does have the correct mag and carb on it. It was restored several years ago and still looks good. Everything has narrow fronts too. Thanks in advance for your help, Lee.
