Re: Farmall F12 govenor
Posted by Craig45 on March 22, 2014 at 06:04:27 from (96.241.138.46):
In Reply to: Farmall F12 govenor posted by James Williams on March 21, 2014 at 08:00:30:
I had the governor off on my f 12 and it isn't that hard of a job. I just loosened the gas tank straps, took the hood off so you can disconnect the linkage from the carb. Remove the two bolts from the front fuel tank support. Disconnect the throttle linkage. After you take out the three bolts holding the gov. On you can pull it out and with a little wiggling remove it. It would be a lot easier to work on it with it off. This is from memory so I might have missed something.
