Re: Sleeve Puller Puck Size
Posted by rustred on March 24, 2014 at 20:32:00 from (74.214.152.80):
In Reply to: Sleeve Puller Puck Size posted by IAtractorKid on March 24, 2014 at 09:58:19:
just save the measurement hastle, if you know u r replacing sleeves just take the new one to machine shop and the machinist will make it correctly the first time. the outside diameter has to be about .010 smaller than sleeve diameter.
that's if your not doing the machining yourself. needs to be at least 1" thick. 100.00 dollars later you have a good puck, that's why let him do it. if you hand him spec's and then it don't work, that your baby then.
