Re: 450 lp no start
Posted by John A. on March 24, 2014 at 21:44:25 from (64.128.16.238):
In Reply to: 450 lp no start posted by johndeerered on March 24, 2014 at 21:26:46:
JD, Sounds like the Diaphragm has a hole in it....
Dead cold All LP tank valves OFF,... Ignition ON, start cranking the engine, crack open Vapor valve I will bet it starts....If it does then you need a new Diaphragm! Hope this helps.
Later,
John A.
If you need a another Diaphragm there are 2 options to you,... buy s used Vaporizer off of E-bay or C.L. and simply remove / replace the vaporizer. or Buy a new on from some place, there are a few guys around that make new ones but some-guys claim they are too stiff.
Holler back if it works or Not.
If you want to call my # is 512-577-3837.
jas
