Re: 3488 hydro - pros, cons, overall rating good, bad?
Posted by DeltaRed on March 24, 2014 at 22:03:23 from (65.100.146.210):
In Reply to: 3488 hydro - pros, cons, overall rating good, bad? posted by michaelr on March 24, 2014 at 15:40:16:
I've seen several Hydros that were big tractors/main workhorses.The thing is you have to know how to run them.When working,open the throttle;Put the thing in LOW range.dont 'push' it,let it 'breath'.It will last a long time,especially on a small farm.Dont let 'hearsay' discourage you!Yes,they do use a bit more fuel than a gear drive,but not a dramitic amount.The fuel consumption on my 826H is not much different than my turbocharged 706(310).Shoot,40 acres of farm isnt enough to worry about.I just got done with water'marking'/corrugateing/listing 90 acres of hay ground with my 826.Had a freind that farmed over 320 acres irrigated ground with a 1026 and hydro 100.other friends/neighbors had/used 1026,H100/H186/1066H tractors.Pulled 4 bottom plows,big disks.....No one ever had a problem with any of them.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
