Posted by Centex Farmall on March 25, 2014 at 07:26:20 from (72.105.164.114):
In Reply to: 450 lp no start posted by johndeerered on March 24, 2014 at 21:26:46:
Could be stuck regulator as John A says or could be the filter is plugged up. They typically don't get changed like they should.
With just the vapor valve cracked open, loosen a fitting south of the filter and see if there's pressure. Try it at the regulator too and see how far along fuel is getting. If it's been sitting a while I'll bet there's a sticking valve in the regulator.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
