Posted by Sparky70 on March 25, 2014 at 14:13:18 from (74.118.207.185):
In Reply to: M Loader Fit Up posted by Sparky70 on March 25, 2014 at 10:01:56:
rustyfarmall & mkirsch
X2 on the picture of the whole loader, it would be helpful.
REPLY: Ask and ye shall receive
If it came off an M, then you shouldn't have to drill holes or cut anything. Those holes have to line up somewhere.
REPLY: Thats what I thought, so I guess it did not come off a M or previous owner M modified cause the front brackets match nothing in the front....unfortunately
Many loaders on tractors of that era bolt to the frame rails near the front bolster, or to the front bolster itself, and clamp on to the rear axle housings.
REPLY: That is the approach I am measuring to
If you can "mock up" the loader where it will be on the tractor by laying the side frames near where they clamp to the axle, you will be able to determine where that front bracket attaches.[/quote]
REPLY: We are on frequency! Cant really mock up yet but I sure can measure close. Plan was to fine tune the brackets and pull the M under the loader, check fit up, adjust, then paint loader.
Don't laugh too hard, I got this for scrap money and was told it came off a M. Hate to call someone a L;;;, but if all M frames the same it sure is not a plug and play for me.
Total distance between where the loader will fit to the rear axle and the front brackets is just about 192" (see pic). In order to make it fit without shortening the loader I need to install the front brackets forward of the bolster a few inches
Hopefully the attach pic explains. I can modify the front bracket as annotated. Wouldn't you know after I verified the location for the front bracket, the 1/4" vertical bar in the bracket was right in line with the bolster taped holes. Also, you can see the bracket holes are on an angle and the bolster holes are plumb perpendicular with the world. So, more doubt about coming off an M.
My own fault, being semi retired I often tackle "bargains" that turn out allot of work. As I see it I either modify the brackets or shorten the loader a couple of inches. I am leaning on fab/modify front brackets cause if I shorten the loader I still have to modify the front brackets or build new ones so they line up with the frame bolt holes. The rear axle brackets will need some fine tuning but no big deal. The front loader width coincides with the M and the rear axle loader bracket width is ok with some bracket adjustments to fit.
Sorry folks, but I would like to know what kind of loader it is.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
