Re: VOLTAGE REG.
Posted by John T on March 27, 2014 at 15:49:59 from (68.243.62.90):
In Reply to: VOLTAGE REG. posted by jeeper55 on March 27, 2014 at 10:41:10:
"how do you check the gen. to see if it is charging."
If the charging system is working and assuming the battery is basically okay, with the tractor at fast RPM the battery voltage should rise from the normal when setting 12.6 volts up to 13 and near 14 depending on the battery and RPM and system. Also a working properly wired ammeter should reflect the rate of charge which may be from a few up to as high as 20 amps subject to battery and its condition etc.
For complete non charging troubleshooting and how to tell if non charging is the fault of the genny versus the voltage regulator or other things work my Troubleshooting procedure linked below.
John T
