Posted by John M on March 28, 2014 at 03:36:08 from (209.213.28.157):
In Reply to: Re: W-4 Won't go uphill posted by Tim in New York on March 27, 2014 at 17:16:06:
Level is NOT your problem, unless theres some funky kind of sediment bowl assembly. HAd one with a short piece of pipe installed, about an inch higher than it was suppose to be. Problem is your carb is running out of fuel First off, the filter should be for a gravity feed system, other wise it could cause the problems your having. Ill assume its OK, so Id start by check fuel supply by check flow from the tank to the carb, should be a good steady stream from the tank to the carb, Check the filter in the carb, clean as needed. With the drain on the carb open and fuel line connected, should flow a good steady stream.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
