Posted by DeltaRed on March 29, 2014 at 15:07:57 from (65.100.144.27):
In Reply to: Super K Loader posted by boomer22 on March 29, 2014 at 09:20:21:
Your 706 is only 70 hp(My 'turned up' turbocharged 706 is still 'only' 96 horse).The hydralics will handle the loader,but they may be slow,as it only is a 12 gpm pump generateing 1450 psi.You should install a 'power beyond' circute so you can still use the rear remotes.A pto pump would be a far better choice to power the loader,as that will produce around 20 gpm and 2000-2500psi.In answer,yes the 706 will handle that loader just fine with no problems.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
