Re: 766 remote valve question
Posted by DeltaRed on March 29, 2014 at 21:36:00 from (65.100.144.27):
In Reply to: 766 remote valve question posted by Jeff cummins on March 29, 2014 at 20:40:39:
Acctually,nothing.work the lever to let pressure off hose,but so far that the pressure comes on. or,push the lever completely down to the 'float' position.The "little knob" is on earlier tractors.'06 and newer dont have or need it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
