Re: 468 cult
Posted by mazemeister on March 30, 2014 at 05:49:57 from (173.3.242.74):
In Reply to: 468 cult posted by farm-al on March 29, 2014 at 16:13:22:
no pics but got one on an 806 right now. there are 3 brackets- 1 bolts on the front using the same holes as a suitcase weight bracket and 2 on the side rails. the front one would bolt up the same on either tractor since the bolt pattern is the same, but i'd imagine that to make the cult work on a X66 they probably would have had to stretch out the pipe part of the cult frame that goes across the front. so if you can visit, see if it looks like that pipe has been cut and welded.
to make it work on an X06 you could make some spacers to go between the frame rails and the side brackets or do some welding and narrow it back up to original specs, assuming that is what was done to it.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
