vertical distributor
Posted by oregonfarmer on March 31, 2014 at 07:59:25 from (70.210.138.10):
It took a while to find the housing so I could put a distribuor verticaly mounted on my M. Some wondered why I would want to replace the magneto anyway. The M has a hydraulic pump running off the cam gear and then comes the vertical distributor housing. I was going to use a IHC dist (one that seems to fit all models), but the gear is wrong. THe drive gear is a worm and doesn't mesh with the dist gear. Is it possible that these verticals were intended for use with a Delco and not IHC?
