Re: 806 HYD. WEAK
Posted by the tractor vet on December 20, 2000 at 17:54:26 from (216.196.12.105):
In Reply to: 806 HYD. WEAK posted by todd on December 20, 2000 at 08:53:10:
Check the perssure with a good gauge that is capable of at least 3000LBS you should have 1500 to 1750 LBS. If you have that much and you need more then install a new stile relief valve it will give you 2150 to 2250.If your pump is in good shape.
Post A Followup
: Re: Re: 806 HYD. WEAK
