Re: 1206 missing a gear
Posted by Owen Aaland on March 31, 2014 at 15:23:09 from (216.47.34.188):
In Reply to: 1206 missing a gear posted by Toby Harter on March 31, 2014 at 12:23:00:
If this problem just happened and the tractor has not been used much you may be able to get by with doing a split between the center section and rear frame and reinstall a nut. Most likely the center section will have to come out and the front bearing replaced along with possibly the counter shaft and gear. With the nut off the shaft moves forward allowing the rear gear (1rst) to come off the shaft. The splines of the shaft then ride on the front needle bearing and tears it up. If run long enough it can wear through the bearing and damage the casting. I have also had the shaft splines damaged so much the rest of the gears could not come off. You then end up using the fire wrench to take it apart.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
