Posted by mkirsch on April 01, 2014 at 04:53:56 from (65.199.189.6):
In Reply to: super a torque posted by farmall4856 on March 31, 2014 at 17:37:30:
I just did the head on my 240, which is basically the same.
There are 9 bolts. A row of 4 along the manifold side, and a row of 5 along the distributor side.
Standing on the distributor side:
1 - 2 - 3 - 4
5 - 6 - 7 - 8 - 9
I started with bolt #7, then #3, then #2, then #6, then #8, then #4, then #1, then #5, then #9, then #4.
Torque spec is 65ft-lbs in the book, but I did some research and several knowledgeable sources have told me the spec was updated to 80ft-lbs. I torqued in 4 stages, snug, 40, 60, and 80.
Right or wrong, that's what I did, and I got away with it so far.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
