Re: F12 sleeve diameter
Posted by FarmallCT on April 01, 2014 at 09:52:36 from (72.10.102.3):
In Reply to: F12 sleeve diameter posted by F-12 guy on April 01, 2014 at 09:34:23:
The inner diameter is 3 inches I believe, same as the farmall A/B/C sleeve. Just add a little to that and you should be good. Tractordata.com should have the measurements if you want to double check.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
