Re: Restoring IH Cultivator Set - Need Input
Posted by Janicholson on April 01, 2014 at 16:41:38 from (74.60.94.18):
In Reply to: Restoring IH Cultivator Set - Need Input posted by RTR on April 01, 2014 at 08:27:58:
Three Ideas for you:
If the Push pull motion of a joint is sloppy from ovaled out holes I either put in larger bolts after drilling them round, or drill then insert a tube that matches the new hole diameter and has an inside diameter of the old bolt (through both the inner and outer parts of the joint). This would allow the use of an old bolt, or a new bolt of the original diameter.
Sometimes a washer can be welded to the worn out hole to reinforce the position if side to side space allows.
Welding up the holes (gas welding is preferable as one can use mild steel and be able to drill the holes out to size) then using new bolts.
If originality is not important and usability is, Heim Joints can be purchased that can replace the worn linkage joints (google Heim joints)
Some locations can have new holes drilled next to the old holes to allow "new" control.
Jim
