Re: Farmall m trouble
Posted by El Toro on April 01, 2014 at 18:29:02 from (96.244.7.206):
In Reply to: Farmall m trouble posted by Brady miller on April 01, 2014 at 17:59:51:
See if the rotor rotating when cranking. You may have damaged the cam gear. Bring No1 piston near the radiator to tdc on the compression stroke. Then remove the distributor cap and see where your rotor is pointing. It should be at the No1 plug tower about one o'clock. Hal
