Posted by mazemeister on April 01, 2014 at 18:46:27 from (173.3.242.74):
In Reply to: Re: 826 park lock posted by Pete on April 01, 2014 at 15:23:15:
i assume you're talking about the range trans cover? i believe once you get it out of park you should be able to lift the cover at least a little bit. if you lift it and take along the vertical shaft that goes down to the reverse fork, then you'll have to drain some oil and remove the side cover for reinstall. however, i think if you put it in high, you can leave that rod behind and line it up with the top cover on reinstall. maybe one of the experts can chime in here to verify?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
