Re: Farmall m trouble
Posted by Janicholson on April 01, 2014 at 20:00:08 from (74.60.94.18):
In Reply to: Farmall m trouble posted by Brady miller on April 01, 2014 at 17:59:51:
Assuming it has a after market engine driven Hydraulic pump, or is new enough to allow the use of a Stage 2 SM or newer tractor, it is probably cam related. Either valve cover or tappet cover will tell the tale. Setting the #1 piston at real TDC (whether compression or exhaust) will allow the rotor to point at either #1, or #4. If not it is the cam gear. If the rotor lines up it could be a broken cam, Jim
